claytonb
Aug 29, 2017Aspirant
Setting up ReadyNAS 314 and CyberPower UPS
Hi, I have a ReadyNAS 314 unit and a CyberPower UPS connected to USB and would like to configure it for the ReadyNAS but am a little confused how to do this, can someone please help me do this? cheer...
Icewaterhot
Aug 29, 2017NETGEAR Employee Retired
Manage UPS Devices
You can manually add, edit, and remove UPS devices as well as monitor the status of connected UPS
devices.
Add a UPS
If your UPS is not automatically detected when you connect it to your ReadyNAS system, you must manually
add the UPS.
To add a UPS:
1. Log in to your ReadyNAS.
2. Select System > Power.
3. If not already expanded, expand UPS.
4. Click the + icon next to the UPS heading.
The pop-up Add UPS window opens. The available settings depend on whether you select SNMP or
Remote in the Type pop-up menu.
5. Configure the settings as explained in the following table:
6. Click the Add button.
The UPS is added to the UPS section.
