Willy47
Apr 29, 2016Follower
Setting up Readynas NV +v2
Is it possible set up the Readynas NV +v2 to run as 2 mirror pairs? Thanks, Willy.
Retired_Member
Apr 29, 2016Hi,
Do you mean having two separate RAID1 volumes on a NV+ v2?
You can do that with Flex-RAID.
See User Manual (page 21): http://www.downloads.netgear.com/files/GDC/READYNAS%20ARM-PLATFORM%20(DUO%20V2,%20NV+%20V2)/RAIDiator%205.3%20SW%20Manual_5Sep12.pdf
- JennCApr 29, 2016NETGEAR Employee Retired
Hello Willy47,
It can be configured on FlexRAID. On RAIDar you can select FlexRAID and choose which RAID level but it does not show which disk to use, normally on OS4 and OS6 when you do this, you get to the admin page and create 2 different volumes with RAID1 each, however, I do not remember an option of doing this creating 2 or more volumes on the dashboard.
Welcome to the community!
