joe_wht
Sep 25, 2016Luminary
Setup Volume Raid 6 with encryption - Unable to connect ???
I just added a 4th 3TB ( all approved same WD HD's ) --- BEFORE doing anything I made sure the firmware was UTD. The ReadyNAS took 2 days syncing it, then I rebooted. A few hours ago I DELETED th...
- Oct 04, 2016
I am able to reproduce your issue, and we've got a fix ready. If you update to 6.6.0, then enable Secure Diagnostics Mode and PM me the 5-digit number, I can get your system patched.
Sep 25, 2016Guru - Experienced User
What status is RAIDar giving you for the NAS.
joe_wht wrote:
Give us multiple security options. I JUST Don't want someone coming over my networkpeeking around. However, I want my Cell, Laptop (username), & Desktop(username) to have full access.
I hope you realize that encrypting the RAID volume has nothing to do with network security. It operates purely locally in the NAS. The data read from the volume is decrypted immediately by NAS, similarly for writes.
- joe_whtSep 25, 2016Luminary
RAIDar states:
RAIDar could not find any NETGEAR storage on your network. Check that your storage device is powered on and connect correctly. for more help . . . .
I figured that since (if) ReadyNAS was busy & I destroyed the only volume, there was nothing for RAIDar to find
- StephenBSep 25, 2016Guru - Experienced User
joe_wht wrote:
RAIDar states:
RAIDar will normally find the ReadyNAS if it is powered, even if there are no disks installed.
Does the NAS respond to ping?
YES..
ping -c 5 192.168.1.26 & 192.168.1.33
sent and recieved back 5 responces.
SO... Genie & the pings can see it..
Maybe it's just too busy with creating and encrypting?
I've just never NOT been able to see the ReadyNAS page.
PING 192.168.1.26 (192.168.1.26): 56 data bytes
64 bytes from 192.168.1.26: icmp_seq=0 ttl=64 time=0.442 ms
64 bytes from 192.168.1.26: icmp_seq=1 ttl=64 time=0.226 ms
64 bytes from 192.168.1.26: icmp_seq=2 ttl=64 time=0.243 ms
64 bytes from 192.168.1.26: icmp_seq=3 ttl=64 time=0.233 ms
64 bytes from 192.168.1.26: icmp_seq=4 ttl=64 time=0.229 ms
--- 192.168.1.26 ping statistics ---
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.226/0.275/0.442/0.084 ms
Joes-MacBook-Pro:~ admin$
