peet1's avatar
peet1
Guide
Nov 06, 2016
Setup wizard will not start after USB recovered 6.6 on Readynas Pro Pioneer
I upgraded My Pro Pioneer to 6.6. It was working well but in an un-related screw up on my part it was acting up, so I used a USB recovery tool to lay down a fresh 6.6.  I've done the same thing several times before with no issues on Pro 6 hardware.
However, afer I log in on https://NASIP/admin/wizard.html, I get an "Error Reporter, Communication Error" with a details button that only reviles "Communication Error" and the time.
Not sure where to go with this. I took a peek at the logs and just don't se anything odd.
Any ideas?
Thanks.com
  • I'm wondering if the issue is the serial number issue that's mentioned here: https://community.netgear.com/t5/Using-your-ReadyNAS/6-5-RC-on-Pioneer-Pro/m-p/1082239#U1082239.
    From my boot_info.log:
    cause: normal
    vendor: ‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1aa
    model: ‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1a‡πS1aa
    model_valid: 1
    version: 6
    serial: ‡πS1a‡πS1a‡πS1a‡πS1a‡πS1aa
    loader: ‡πS1a‡πS1a‡πS1aa
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You should only do USB Boot Recovery if there is a problem on the internal flash. Usually USB Boot Recovery is done when it isn't needed.
    • peet1's avatar
      peet1
      Guide
      That makes sense.
      Yeah, I won't lie, USB recovery is a lazy way for me to get the result that I want.
      However, I don't necesarily think my current issue is caused by the recovery.  My first recovery was from the internal flash and I ran ito the same issue.
      Cheers.Peet
        mdgm-ntgr
        It may/may not have been the case here but often when USB Boot Recovery there is a problem with something on the disks e.g. the OS partition and nothing wrong at all with the firmware on the internal flash. USB Boot Recovery's sole purposes is to wipe the flash, format it and put a clean copy of the firmware on it.
        If the problem is not with the internal flash then you risk creating an additional problem without fixing any.
ProSupport for Business
