SergejS
Dec 14, 2020Aspirant
Share folders are not visible in the web interface ReadyNAS 316 Firmware: 6.10.3
Hello dear community, I have a problem that a folder can only be accessed through Windows Explorer \\ x.x.x.x \ "Share name" \ can be seen, but not via the web interface! Does anyone have any ide...
- Dec 15, 2020
Great!
Thx for following up. :smileyhappy:
Dec 14, 2020Guru - Experienced User
Is it possible that this is a private home folder, and not a public share?
If it was in the share list before, then is is a public share.
If the name matches a NAS user account name (including admin), then it is a private home folder.
- SergejSDec 14, 2020Aspirant
Thanks for your answer, my problem is that I have deliberately not made any changes to the system and shares.
I am logged in as an admin and have full access rights.
Only the folders are no longer visible. See the screenshot- StephenBDec 15, 2020Guru - Experienced User
It would be wise to make a backup.
After that, you could try running the script here: https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh
That will require you to enable ssh access on the NAS. Log in as root using the NAS admin password.
- SergejSDec 15, 2020Aspirant
Thank you very much,worked great!!!
:smileyhappy::heart:
= [Task] Discovering volumes
== [Info] 1 volume(s) found.
==== [Task] Backing up existing Snapper configs
===== [Info] Success at backing up snapper configs
===== [Task] Removing Snapper Configs
== [Task] Investigating volume /data...
=== [Info] Number of items found : 5
=== [Info] Items found: Bilder Dokumente Franken-Solution Musik Videos
=== [Task] Reviewing Bilder
=== [Info] Found share at /data/Bilder
=== [Task] Recreating share configs.
==== [Info] Done with Share /data/Bilder.
=== [Task] Reviewing Dokumente
=== [Info] Found share at /data/Dokumente
==== [Info] Done with Share /data/Dokumente.
=== [Task] Reviewing Franken-Solution
=== [Info] Found share at /data/Franken-Solution
==== [Info] Done with Share /data/Franken-Solution.
=== [Task] Reviewing Musik
=== [Info] Found share at /data/Musik
==== [Info] Done with Share /data/Musik.
=== [Task] Reviewing Videos
=== [Info] Found share at /data/Videos
==== [Info] Done with Share /data/Videos.
