davidr1
Jul 27, 2017Luminary
Share not showing in Frontview
Ultra with OS6 6.7.5 I created a share in Frontview as per normal procedure. As I don't run windows I only gave it nfs and rsync access with the normal ip addresses I use and the normal owner an...
- Aug 01, 2017
How about btrfs subvol delete /data/Backups_Weekly_of_212/.snapshots
JennC
Jul 31, 2017NETGEAR Employee Retired
Hello davidr1,
Could you check if you will get the same results when you use another web browser? Perhaps you want to try creating a new share again leave SMB enabled also then check if you get the same results.
- davidr1Jul 31, 2017Luminary
Thanks for replying JennC,
It happens in other browsers as well.
I can create and see new shares - already did this but did not configure with smb - none are.
Can I just delete it from /share using ssh or is it registered in a database of shares or something?
Also, if I do a factory reset using OS6 on the Ultra, which OS would it reset to?
- JennCJul 31, 2017NETGEAR Employee Retired
Hello davidr1,
Yes, you can try
rmdir <sharename>
And then create a share
rn_nml [-v] -a share:/data/<sharename>
I believe this should show the share on admin page and SMB is enabled by default.
