davidr1
Jul 27, 2017Luminary
Share not showing in Frontview
Ultra with OS6 6.7.5 I created a share in Frontview as per normal procedure. As I don't run windows I only gave it nfs and rsync access with the normal ip addresses I use and the normal owner an...
- Aug 01, 2017
How about btrfs subvol delete /data/Backups_Weekly_of_212/.snapshots
davidr1
Jul 31, 2017Luminary
Thanks for replying JennC,
It happens in other browsers as well.
I can create and see new shares - already did this but did not configure with smb - none are.
Can I just delete it from /share using ssh or is it registered in a database of shares or something?
Also, if I do a factory reset using OS6 on the Ultra, which OS would it reset to?
JennC
Jul 31, 2017NETGEAR Employee Retired
Hello davidr1,
Yes, you can try
rmdir <sharename>
And then create a share
rn_nml [-v] -a share:/data/<sharename>
I believe this should show the share on admin page and SMB is enabled by default.
- davidr1Jul 31, 2017Luminary
Thanks JennC.
If I factory reset the Ultra which uses OS6 would it reset to OS6?
I can't find any info on this.
- JennCJul 31, 2017NETGEAR Employee Retired
Hello davidr1,
I think it will load the OS6 still since part of the upgrade from OS4 to OS6 is factory reset.
Many thanks JennC.
- SandsharkJul 31, 2017Sensei
A legacy system running OS6 will act like a newer system when you do a factory default or an OS re-install -- it will re-install the currently loaded OS6 version. The only thing that you have to do differently, and few need to do it at all, is USB recovery.
