pl804
Aug 10, 2018Guide
Shares disappeared after partition filled
A few days ago, network access to my ReadyNAS became unreliable. I logged into the control panel and saw a warning in the logs that the root partition was >90%. I SSHed in and deleted a mess of wha...
mdgm-ntgr
Aug 13, 2018NETGEAR Employee Retired
pl804, I've sent you a PM.
If you want to troubleshoot it yourself start by doing e.g.
# mount --bind / /mnt
Then you need to look in /mnt to see what's using up the space e.g.
# du -csh /mnt/*
# du -csh /mnt/var/*
Depending on what you find it will depend on what needs to be done to proceed.
When the root volume is full some config files may get corrupted leading to additional steps being needed to resolve the problem. It sounds like that has happened in this case.
You can look under /data/._share/ (where data is the volume name) to see if the config files are still there. If they are then you could do e.g.
# cat /data/._share/*/samba.conf > /etc/frontview/samba/Shares.conf
Or,
# touch /var/readynasd/.need_export
# systemctl restart readynasd
If the config files on the data volume are corrupt then they'll need to be manually recreated.
- pl804Sep 04, 2018Guide
()Thanks, both. I tried replying to the PM but it says I've reached my limit.)
So I thought I had fixed it. I renamed the old shares, created new shares in the Control Panel, then copied the files from the old shares into the new shares. All was well, until Disk 2/6 and 4/6 started showing errors. I replaced Disk 4, only to get wind up with another bad disk (the RMA unit). I went on vacation, and during that time, the volume went from degraded to dead. So I think I'm toast.
- pl804Sep 06, 2018Guide
A little more detail and a question:
I thought I had fixed the issue on my rn716x by renaming my old shares, creating new shares, and copying the files from the old shares to the new shares. All was good for a few weeks.
Then, 2 disks started showing errors. I did an advance RMA but foolishly started wiping the old bad disk before the new one was resynced. It failed to resync b/c it too had sector errors.
At that point, I went on vacation, during which time, the other bad disk failed, and the volume went from degraded to dead.
I tried cloning the disk that failed, but I guess it's out of sync now. Do you know if there's any way to get it back in sync?
I started looking at ReclaiMe and their RAID recovery tool, but can't tell if it will work with my X-RAID configuration.
Thanks for any advice/help.
- StephenBSep 07, 2018Guru - Experienced User
ReclaiMe does work with OS 6 XRAID volumes, and several users have reported success using it.
Technically no. Once it's out of sync, the only way to sync it is to rebuild it from the others. That can't be done if you have multiple failures.
But it is possible to force the out-of-sync disk into the RAID array. However, it is risky - there is certain to be some file system corruption. Some of that is because of errors on the disk, the rest is because it isn't in sync.
RAID recovery is probably the only real option. You could use Netgear support btw - https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service.
