fooboo
May 20, 2016Star
Shares disappeared after restarting Frontview manually.
ReadyNAS NV (I know, I know) running latest firmware. Been a faithful user for years. Somewhere between restarting frontview and nfs-kernel-server via command line (in an attempt to tighten ...
kohdee
May 20, 2016NETGEAR Expert
You might be able to try restoring the original config files from /etc/default/config/etc/frontview
cp -rP /etc/default/config/etc/frontview/* /etc/frontview/
- foobooMay 20, 2016Star
Oh cool!
I found a (semi?) intact Shares.conf at
/etc/default/config/etc/default/samba/Shares.conf (it's missing /c/u001 and /c/vmdatastore)
[backup]
comment = "Backup Share"
path = "/c/backup"
public = 1
writeable = 1
oplocks = 1
[media]
comment = "Media Server Share"
path = "/c/media"
public = 1
writeable = 1
oplocks = 1
Similarly, /etc/default/config/etc/netatalk/AppleVolumes.default
After restoring the files and cleaning out /etc/passwd, what do you recommend as the best way to restart things? Reboot or restart services? (AFP, CIFS and NFS are all currently impacted for me).
- kohdeeMay 21, 2016NETGEAR Expert
No, that's actually the default config file; that's the config it would have used if you factory defaulted. You can copy the default config Shares.conf to the /etc/frontview/samba/Shares.conf to match your existing shares and get yourself back up and running. You might also be able to check /var/backups/ to see if there is a config backup there of your original shares.
- foobooMay 21, 2016Star
Ok thanks. I looked in /var/backups and it appears that there are a number of compressed tars there so I'll copy them off and look around.
- Is it safer/better to either cherry pick the files that I need or just copy it over completely?
- I'm assuming that I should reboot after copying the files over? Or should I just restart frontview from the command line?
Thanks much! I'm excited about the prospect of getting things back to normal.
