bengsig
Aug 24, 2024Aspirant
Shares lost from admin page
My ReadyNAS 212 has lost all shares and I only see: I have looked at other articles mentioning the same, and I have checked I am not running out of space. And also, when I ssh to the system, ...
- Aug 25, 2024
bengsig wrote:
However, clicking update, I am told I am on the latest so I cannot upgrade to 6.10:
First of all, you are seeing that message only because you've chosen to set "Check for Updates" to "long term stable" on the system->settings->update page. You can just change that setting to "stable" and you will get 6.10.10
However, if you have apps installed, then I suggest stopping at 6.10.9. 6.10.10 removes the ability to install apps from the web admin apps page.
You can download 6.10.9 from here:
Extract the firmware from the arm zip file, and then install it manually (system->settings, then press the "install firmware" button in the middle of the page.
bengsig
Aug 25, 2024Aspirant
As I also wrote initially, I am not running out of space:
so the root partition has ample free space. I also heard about the script mentioned, and would very much like to have it.
Thanks!
Aug 25, 2024Guru - Experienced User
This was written by a Netgear developer for support use some years ago. Unfortunately, the last time I checked, the certificate had expired.
However, you can still run it using these steps:
# cd //
# wget --no-check-certificate https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh
# chmod +x ./share_lun_ui_fix.sh
# ./share_lun_ui_fix.sh
- SandsharkAug 25, 2024Sensei
Or, you can just download it with your browser and put it on the NAS instead of using wget. You still need to do the chmod to make it executable. It's just a text script. What you don't get, but bypassing certificate checking also does that, is some verification it's not been spoofed.
- bengsigAug 25, 2024Aspirant
Thanks a lot for pointing me at that script. However, https://gitea.threefifteen.info/readynas-scripts/share_lun_ui_fix.sh/src/branch/master/README.md tells me I need to be on ReadyNAS OS 6.10.0 or newer, and my ReadyNAS 212 is on 6.9.6. However, clicking update, I am told I am on the latest so I cannot upgrade to 6.10:
Any other suggestions?
- StephenBAug 25, 2024Guru - Experienced User
- May 30, 2016Retired_Member
