ljcorreia
Sep 21, 2015Aspirant
Shares lost
Hi, I own a ready ReadyNas Duo (RND2110v2) for nearly 6 years. The NAS has lost all shares, but all files are there and accessible through SSH (WinSCP). In order to understand if this may...
- Sep 22, 2015
You have a full OS partition (/dev/hdc1)
Can you check to see how much space is used in /var/logs
ljcorreia
Sep 24, 2015Aspirant
Ahh ok, I thought that could be the case. So in that case it means that I won't be able unless I install the add on that allows root access, but if that module is installed Netgear may offer no support, right?
mdgm-ntgr
Sep 24, 2015NETGEAR Employee Retired
Not sure how you were able to SSH in not as the root user. If you SSH in by any method then we may deny support. It is at our discretion, but generally this would be if we suspect the problem is related to misuse of SSH.
I think you can ignroe the error messages about that presence file.
