dschwartzer
May 07, 2017Luminary
Shares now Read Only after Updating to 6.7.1
I have an RN526X as my primary server and use a RN314 as a backup server. Yesterday, I upgraded both systems to OS 6.7.1 Each night at 10:00, the RN 526 sends an incremental backup to a folder o...
vandermerwe
Jun 10, 2017Master
I don't have an answer for you but I have posted about this problem several times before and never got an answer.
This is one of the threads:
I have factory defaulted my unit several times as this seem the only way to clear the read-only file sytem error.
I have pretty much isolated the cause to ReadyDR -the unit ran normally for 2 months recently and within 10 days of activating ReadyDR jobs I have the dreaded read-only filesytem error. I have run memory tests and extended disk tests on all disks.
Interestingly once the error appears I can delete the ReadyDR jobs, but not the ReadyDR shares - I get a "failed due to snapshot deletion failure "error
I am running OS 6 Ready DR on a legacy unit which may be why I haven't had much interest from Netgear, perhaps now that there are others with similar issues on newer machines we may get an answer.
I have logs if anyone interested.
Another factory default coming up and I'm abandoning ReadyDR.
mdgm-ntgr
Jun 13, 2017NETGEAR Employee Retired
It would be good if you could send in logs.
Support has got a case that they suspect might be related (though something that appears to be related at first glance may prove to be quite different).
- vandermerweJun 13, 2017Master
Logs sent.
I sent in logs in April when this happened before.
- dschwartzerJun 13, 2017Luminary
Logs for both the 526X and 314 have been sent.
