amtrakuk1
Dec 08, 2015Aspirant
Shares very slow / time out after firmware update
Hi there. I have a Readynas 104 which has been working fine but since a firmware update to 6.4.1 the LAN performance is horendious to the point of un-usable, tpically taking 10 seconds to browse share...
Dec 08, 2015Guru - Experienced User
If you have the antivirus service enabled, disable it for now.
It's a known bug, hopefully it will be fixed shortly.
ohboy710
Thank you! Arter hours of screwing with this I finally read this post. I wish there was some way to get on an email list so if something major like this bug is realized, we could get notified instead of being frustrated when it's a known issue, we just don't know it. Either way thanks!!!
- BrianL2Dec 08, 2015NETGEAR Employee Retired
Hi ohboy710,
Most problems and issues were discussed or raised in the community. We are still waiting for the firmware that will fix the issue mentioned in this thread.
Kind regards,
BrianL
NETGEAR Community Team
