sooveryconfused
Aug 05, 2019Tutor
Shares visible on network but not in web gui
Hello all! I have been combing through the community trying to find an answer to this without any luck. So here goes. I have a ReadyNAS 516 (firmware 6.9.5) and it has been a wonderful NAS. I am ...
- Aug 13, 2019
I tried all of these methods without any luck on changing the visibility. Again, I can see the share in SSH but still cannot see them in any web browser. I ended up creating a new folder and then coping all of my invisible shares into it using the mapped drive through Windows. I was able to use command line to get the copying completed faster.
Once I verifed that everything was copied to the visiable share, I deleted all of the hidden shares. It took about 10 hours to do this but it has solved the problem.
Thank you all for all your help and suggestions!
Aug 05, 2019Guru - Experienced User
Is this a "private" share? If so, it would be under "home". You can click on "home" in the web ui, and see if it shows up there.
sooveryconfused
Aug 05, 2019Tutor
Thank you for the reply, by that is not the case. It is a full share, right beside the Home folder.
I have also tried logging in as other users with and without admin credentials. Same thing. All shares show up properly on the network, but not in the web interface.
- StephenBAug 05, 2019Guru - Experienced User
Do you have ssh enabled? If you do, you could list the subvolumes of the data volume there, and make sure it is a subvolume, and not an ordinary folder.
One way to resolve this is to
- create a new share with a temporary name.
- use ssh to delete the temporary subvolume
- use ssh to rename the original share folder to the temporary name
- rename the new share in the web ui to the correct name.
- sooveryconfusedAug 05, 2019Tutor
Thaks for the idea. I do not believe I have ssh on. I don't see it in the web interface, but of course I cannot see the shares I need anyway. Do you have a suggestion on how I can find out if it is enabled?
Look on system->services - it should be listed there.
You need to log in as root (using the NAS admin password). Are you familiar with the linux command line?
- Retired_MemberAug 05, 2019
Hi sooveryconfused, did you try using different browsers to exclude the issue is coming from that side? E.g. Firefox can behave a bit weird when it comes to displaying objects or impacting their behaviour, if you configure its security in a very strict way. Chrome or Edge might be worth a try, of course native, which means no add-ins and only default configuration parameters.
Kind regards
I did try different browsers when I first noticed the issues. It is the same in Chrome, Firefox, IE, and Safari. :(
