sooveryconfused
Aug 05, 2019Tutor
Shares visible on network but not in web gui
Hello all! I have been combing through the community trying to find an answer to this without any luck. So here goes. I have a ReadyNAS 516 (firmware 6.9.5) and it has been a wonderful NAS. I am ...
- Aug 13, 2019
I tried all of these methods without any luck on changing the visibility. Again, I can see the share in SSH but still cannot see them in any web browser. I ended up creating a new folder and then coping all of my invisible shares into it using the mapped drive through Windows. I was able to use command line to get the copying completed faster.
Once I verifed that everything was copied to the visiable share, I deleted all of the hidden shares. It took about 10 hours to do this but it has solved the problem.
Thank you all for all your help and suggestions!
sooveryconfused
Aug 06, 2019Tutor
Good morning!
I have enabled ssh to see if i can perform the above recommendation. It appears when I connect via ssh, I still cannot see the shares I am missing. I do still see them when mapping the drive and/or conneting to the sever through Finder.
This seems like some wierd permission issue. I can see the shares through some connection types, but not through others.
Any other suggestions?
sooveryconfused
Aug 06, 2019Tutor
Ah! I was able to get in using a different admin account. I am trying the remanes now.
- sooveryconfusedAug 06, 2019Tutor
Even though I can't spell renames, I was able to see my shares. However, I was unable to delete or rename using the commands above.
I am going to try to mv one of my shares into another folder that I can see.
- StephenBAug 06, 2019Guru - Experienced User
Log in as root, using the NAS admin password.
- sooveryconfusedAug 13, 2019Tutor
