BigAl1
Jan 20, 2019Aspirant
Shares, Where am I going wrong.
I have created a share on my NAS (Perth_Photos) and I think I have done everything correctly, yet when I go to my browser and type in http://1XX.XXX.X.XX/Perth_Photos the browser displays this. ...
- Jan 22, 2019
BigAl1 wrote:
Obviously I can get into the Share via my admin login, but the idea behind all this is that I have just spent 4 weeks in Perth W.A. with my 3 daughters, 2 of which live in Australia, the other lives here in the UK.Well, if http is enabled for the share (not just enabled in system->settings) then http://1XX.XXX.X.XX/Perth_Photos should show it.
Looking again at your screenshot, it appears to be doing that (at least showing folders in the share), so I am unclear on what your problem actually is. If you click on the subfolder links you should see the photos in them. However, you really want remote access to the NAS over the internet, which isn't the same as just enabling http. You'd also need to forward ports in your browser and set up DDNS. And http isn't a secure way to access the NAS remotely, so I recommend using a different approach.
If this is a one-time project, you could just use cloud storage like Google Drive. Google offers 15 GB of free cloud storage (including gmail storage if you use that), and the family downloads wouldn't be limited by your ISP upload speed. If you need more storage, you can temporarily upgrade it for a small monthly fee - then remove the photos and go back to the free account when you are done. You can sync Perth_Photos to your google drive using a built-in ReadyNAS cloud app (though I'd probably upload the photos from a PC myself).
If this is longer-term, then you might want to consider ReadyCloud. You'd create accounts for the family, and they'd use those to access the photos. They can access them from a browser, or they can install the ReadyCloud app and use file explorer. There are a couple of other options (ZeroTier and FTPS/FileZilla), but they are a bit more work to set up.
BigAl1
Jan 21, 2019Aspirant
That's strange as I can see it, but I'll give it another go.
BigAl1
- StephenBJan 21, 2019Guru - Experienced User
I believe you didn't enable http as a protocol on the new share.
Note that from a PC you'd normally be using file explorer (or finder with a Mac), not your browser.
What NAS do you have and what firmware is it running?
- BigAl1Jan 21, 2019Aspirant
Thank you for your reply. I have switched on all the protocols except AFP.
My NAS is a 204 running 6.9.4. which states that it is the latest version of software.
Obviously I can get into the Share via my admin login, but the idea behind all this is that I have just spent 4 weeks in Perth W.A. with my 3 daughters, 2 of which live in Australia, the other lives here in the UK.We have taken over 1,000 photo's and most would be 3 Mb, so to email them to each other isn't going to work.
The idea was for each of us to upload them to my NAS and one of the girls is going to vcreate a photo album.
It was about having all the photo's in one place to start with.Thanks for helping.
- SandsharkJan 21, 2019Sensei
Assuming Windows, don't go to your browser at all. In the Windows search box, type \\1XX.XXX.X.XX\Perth_Photos (note direction of slashes), and it will open Windows Explorer in the share (after you enter the right credentials). You can also use that format to map the share as a drive on your computer.
