hikaricore
Sep 02, 2015Aspirant
Should I worry about "bit rot" with no visable drive errors?
Running my monthly scrub 25% of the way through I've seen 4 reports of bitrot from files I confirmed viable before transfering to my NAS over ethernet. There are literally 0 disk errors or warnings ...
- Sep 03, 2015
I'd do a binary compare of your backup files and the ones on the NAS, and see if they are actually different. Please post back either way.
Sep 03, 2015Guru - Experienced User
- mdgm-ntgrSep 03, 2015NETGEAR Employee Retired
Also, which firmware are you running?
Do you recall which firmware you were running when you added these files?
- hikaricoreSep 03, 2015Aspirant
I did a CRC check from the NAS files to my backup and they're totally off.
Attempts to copy from the NAS filesystem (on these 4 files only) gives an Input/output error via CLI on my desktop Linux system.
Any other files that I've randomly tested pass CRC and playback tests just fine. So that's fantastic. :)
Firmware version is 6.2.4 currently and at the time of transfer.
My scrub still has a day or so left so I'll note any further failures that I come across.
Yes, definitely bit-rot has occurred.
