RonLuxton
Sep 12, 2011Tutor
Should I worry about SATA ?
I'm thinking of adding capacity to my 2009 ReadyNAS NV+ which came with two 500GB Seagate drives, which have - and are - working perfectly. I'm thinking of 2 more 500GB drives. There are plenty ...
dbott67
Sep 12, 2011Guide
SATA II disks will work fine, although they will only run at SATA I speeds - http://www.readynas.com/kb/faq/boot/does_the_readynas_support_sata_ii_hard_disks
Check the HCL for compatible disks: http://www.readynas.com/?page_id=82
