snooker
Oct 07, 2019Star
Shutdown of remote ReadyNAS afer Backup?
Hi, I´m using two ReadNAS Devices, one as my working NAS and one only as a Backup-Device (daily backup via rsync). I learned, that I can wake up the Backup ReadyNAS before the Backup (WOL), b...
- Oct 07, 2019
snooker wrote:
I learned, that I can wake up the Backup ReadyNAS before the Backup (WOL), but I wonder if it is possible to shut it down aber finishing the backup-jobs.
The way I handle this is to run the backup jobs on the destination NAS. That NAS is on a power schedule. The NAS will defer shutdown if a backup job is in progress.
Oct 07, 2019Guru - Experienced User
- snookerOct 07, 2019Star
StephenB wrote:The way I handle this is to run the backup jobs on the destination NAS. That NAS is on a power schedule. The NAS will defer shutdown if a backup job is in progress.
Thanks for the hint! Good to hear, that the NAS won´t shut down during an active backup job.
Thanks and best regards
Jan
- StephenBOct 07, 2019Guru - Experienced User
Note that's only if the backup job is running on that NAS. That's why I run the jobs on the NAS that is on the power schedule.
