rclementtx
Jun 19, 2016Guide
Slow / sporadic interface with iMac
Folks, I have a 1 year old iMac 24" with OS 10.11.5 operating system, hardwired to Netgear unmanged 16 port switch. I'm running a 100Mb backbone on this particular LAN branch back to switch (2 pair...
JennC
Jun 22, 2016NETGEAR Employee Retired
Hello rclemntrix,
Have you tried connecting the iMac straight to the switch where the RN316 is connected and check if it gets the same connection problem?
It could be the travel time that computer takes to reach the whole network to talk to LAN devices when it wakes up, so try isolating the problem first.
- rclementtxJun 22, 2016Guide
Yup. As I explained above, that's how it is connected already. Remember, the jist of my issue is that iMac connectivity with the RN316 is miserable after it wakes after going to sleep. To have a usable connection MOST OF THE TIME, I have to reboot the iMac. After reboot, the connection is tolerable.
- JennCJun 22, 2016NETGEAR Employee Retired
Hello rclementtx,
Can you try connecting the wireless capable machine wired to the switch where the NAS is and disable its wireless functionality then see the same performance?
Jenn,
That's hard to do. MacBook Air is pretty much a wireless machine. I don't have adapters for LAN connection - and if I did, the connection would be at USB speed.
