forquer
Apr 30, 2010Aspirant
SLOW backing up to USB
Hello all! This is my first post here so forgive me if I'm asking something i did not find in the forums already. We have lots of sites with the NV+ NAS and here is our setup; ESX4 with Vrang...
russella1
Jul 15, 2010Aspirant
Thank you mdgm...my old (bad) transfer rate agreed with the chirpa calcs you posted, and after formatting the target USB drive to EXT3, the new transfer rates *also* agree with the calculations...I am now getting around 9.5MB/s. Thank you for the suggestion!
By the way, under the (options) button in frontview, there was only an option for EXT3 format. Since the performance is even better with EXT2, is there a way to get frontview to do that...for next time?
Thx,
Arthur
Thx,
Arthur
mdgm wrote:
russella wrote:
I really want to use NTFS for this, because it will be the only storage repository for my data while I do a factory init on my NV+, and if something (else) goes wrong, I want to be able to access the data easily from a PC. I know there are ways to mount an EXT3 volume from win, but I don't see that it's worth it.
I think it is worth it. If your files are all under 4GB in size per file FAT32 is an option.
russella wrote:
I understand you are implicating the format of the USB disk as the reason for the slow performance. How much faster would it be using EXT3?
See this post which has some rough estimates that chirpa came up with:
chirpa wrote: The speeds are something close to this: NTFS = 2.5MB/s
FAT32 = 5MB/s
EXT3 = 10MB/s
EXT2 = 14MB/s
