forquer
Apr 30, 2010Aspirant
SLOW backing up to USB
Hello all! This is my first post here so forgive me if I'm asking something i did not find in the forums already. We have lots of sites with the NV+ NAS and here is our setup; ESX4 with Vrang...
maxblack
Oct 28, 2011Aspirant
mjw wrote: A new version of ntfs3g is now included in the latest raidiator firmware so there's no need to manually install ntfs3g any more.
I'm not certain this is correct, at least not for the 4.1.8 version running on the NV+. I can certainly vouch for the fact that USB backup using 4.1.8 on an NV+ to a NTFS USB drive is brutally, painfully, impossibly slow.
if your performance is slow then there's not much you can do except make sure you use incremental backups.
Yeah but you gotta get the initial backup made.
I do wonder if it's possible to change the priority of the backup command within the NV+ to make it work faster. As it seems now, the USB transfers are the lowest of the processes, at least for my NV+.
