HomeUser_MA's avatar
HomeUser_MA
Slow Blue Light of Death
I have ReadyNAS Duo (no version), which I have had for years. During a recent storm we lost power which has happened before. Unfortunately this time when I turned the NAS back on the blue power light just blinked and the disk 1 & 2 lights were solid. I tried powering down and powering up the NAS a couple of times with no change in status. After a quick review of the internet, I found that I could reset the OS via the reset button in the back. I powered down the NAS and then pushed the reset button and then powered up the NAS. I held the reset button for 10 seconds (I was waiting for the disk LEDs to blink, which they did at 10 seconds). I have been waiting for an hour or so. But all I get a slow flashing blue light, which every so often will stop flashing for a moment, dim, then the status light flashes once and then the blue light returns to flashing.
All of our pictures for 10 years are stored on the NAS - there are two separate 500MB hard drives in the NAS and I am really not that technical, but I am extremely worried that I've hosed something completely. I could really use help.
thank you
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    It's possible you could accidentally delete a file (would be immediately deleted from both disks), you could have multiple failures and a range of other issues, as well as fire, flood and theft.
    Businesses use RAID in their servers and still backup their data.
    If you only store irreplaceable/important data on one device then you are taking a big risk.
    A few cheap USB disks rotated off-site, another NAS with the first backup on-site and subsequent backups to the NAS over the Internet to a remote location (e.g. to house occupied by parent/sibling/child depending on what suits you - you could even arrange to backup their files back to your place), backup of important data to the cloud are all good suggestions.
    With 500GB disks currently in your NAS it shouldn't cost you that much to implement a backup solution.
    Preferably you should have at least 3 copies of important/irreplaceable data including the primary copy.
  • thank you that makes sense. is there a tutorial somewhere on how to use an external USB drive to back up the NAS? I recall trying to set something like that up when I first got the NAS, but it did not work so well so I gave up and just went with the RAID structure.
  • StephenB's avatar
    I agree with mdgm on the 3-copies (on three devices) approach. You were a bit lucky in this case.
    USB is slow on the duo v1. rsync is one way to make it run quicker. There's a guide from mdgm here: http://www.rnasguide.com/2010/09/23/rsy ... -usb-disk/
    You can also connect the USB drive to a PC, and back it up over your network (wired, not wifi). That is faster, and keeping the USB drive electrically separate from the Duo is perhaps a bit safer.
  • New update - I went away thinking it was fine - but tonight I went to add something to the NAS drives for the first time and none of the computers can mount the drives nor can they login via the web page. Raidar sees the drive, but I cannot access the drive from Raidar either. It says that drive 1 (the drive that seemed to fail before) is at 98% resync and will be done in 4 minutes - it has said this since I logged in an hour ago. I assume that the drive is bad. So I will order a new one. Fortunately, I have the back-up from before.
    Any suggestions other than powering it down and removing the bad drive?
    thank you again.
    mdgm-ntgr
    It does sound like you have a bad disk. Probably there is a problem with disk 1 but you may wish to test both disks using e.g. SeaTools if they are SeaGate disks.
ProSupport for Business
