Donaldini
Jan 05, 2012Aspirant
Slow copying speeds
I'm getting very slow writing speeds when writing to my new ReadyNAS NV+ 1. RAIDiator version: 4.1.8 2. Performance tab settings: 3. Network switch model (and firmware version): C...
mdgm-ntgr
Jan 07, 2012NETGEAR Employee Retired
Congrats on your new NV+ v1 purchase!
I can see that your WD disk is not on the Hard Disk HCL. It could well be the problem and NetGear would deny support to help you troubleshoot performance unless this disk is replaced.
Can you download your logs and check partition.log? If your disks are not 4k sector partition aligned that could be a problem. See http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/
EXT3 drivers are need for Windows and Mac to read EXT3 formatted disks. Neither supports them natively.
