Donaldini
Jan 05, 2012Aspirant
Slow copying speeds
I'm getting very slow writing speeds when writing to my new ReadyNAS NV+ 1. RAIDiator version: 4.1.8 2. Performance tab settings: 3. Network switch model (and firmware version): C...
Donaldini
Jan 07, 2012Aspirant
If I read it right, the discs should be 4k aligned, no?
Also I guess sda is my connected USB disk (because it was gone in the logs when i removed it).
Disk /dev/hde doesn't contain a valid partition table
Disk /dev/hdc: 1500.2 GB, 1500291424256 bytes
255 heads, 63 sectors/track, 182400 cylinders, total 2930256688 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 83 Linux
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
Partition 2 does not end on cylinder boundary.
/dev/hdc3 4608032 2930240335 1462816152 5 Extended
/dev/hdc5 4608040 2930240335 1462816148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
Disk /dev/sda: 2000.3 GB, 2000398934016 bytes
224 heads, 19 sectors/track, 918004 cylinders, total 3907029168 sectors
Disk identifier: 0xe30c5291
/dev/sda1 * 2048 206847 102400 7 HPFS/NTFS
/dev/sda2 206848 1965320191 982556672 7 HPFS/NTFS
/dev/sda3 1965320192 3907024895 970852352 7 HPFS/NTFS
