ndverge
Sep 30, 2015Aspirant
Slow network copy
I have readynas 102 with two 1TB hard disk. I use this nas to backup linux server data. but when i am copying from linux folder to the netgear nas folder, it transfers at the speed of 1.15 MB/ps. I c...
- Nov 27, 2015
Dear all,
My Network slow copy problem is solved by upgrading to 6.4.1. Now it is copying by the speed of 13Mbps over the network. Thanks for the help you supplied me.
ndverge
Oct 12, 2015Aspirant
Dear all,
I am very sorry to reply you so late. Because of our server was down in vpn connections. those days i was attending to that issue.
I still not yet checked the Cable types. but I have checked others:
a. Is the Linux server connected via a Gigabit connection? YES
b. Have you tried changing the ethernet cables? NO
c. Are you using a CAT5e or CAT6 cables? WILL CHECK
d. Have you tried to connect the NAS sirectly to the Linux server then try to transfer files and check if same problem occurs? I tried. it copies files so fast. But from the server to nas via network switch.
e. Have you tried using another Linux PC to isolate the problem? Yes. problem exists but via network over switch.
DaneA
Oct 12, 2015NETGEAR Employee Retired
Hi ndverge,
Based from your answers, it seems that the switch configuration needs to be check since it works fine if the Linux server is directly connected to the NAS.
DaneA
NETGEAR Community Team
- ndvergeNov 27, 2015Aspirant
Dear all,
