Sinage
Jul 24, 2018Aspirant
Slow Running RN104
Hi All,
My RN104 is driving me crazy and I hope someone can help!!!
I have two issues that might be related. Firstly a little background I used to use a NV+2 system that was great howeve...
Sinage
Jul 25, 2018Aspirant
Hi
Thanks for the reply.
I actually tried something obvious last night - I copied a file from the NAs to the HTPC. The 4.5Gb file was copied in less than 5 minutes. However when i looked at the bandwidth figures the copy rate dropped intermittantly to a very low figure and stops sometimes. This is why I think film streaming has issues...it can;t cope with the slow down / halts in data flow.
I have tried both ethernet ports and get the same issue - could this be a hardware issue? I am a bit scared to try to run both ethernet ports paired!
Cheers
Simon
Retired_Member
Jul 25, 2018To my knowledge pairing the two ethernet ports on an RN104 will probably have no effect.
Sorry, I'm running out of ideas. Maybe somebody else could help further.
