hezner1
Apr 24, 2018Tutor
Slow saves for Revit 2018 after OS upgrade from 6.8.1 to 6.9.2
We use the ReadyNAS as a file server for our architectural office. NICs are not teamed. Shadowcopies are not enabled. Everything was working very well until after I upgraded the OS from 6.8.1 to 6....
- May 01, 2018
As a reference to anyone else with this problem, I updated to OS 6.9.3. That version includes the ability to control strict sync on a per share basis. I unchecked strict sync for the affected shares and the save times gone back down to where they were before.
Apr 25, 2018Guru - Experienced User
hezner1 wrote:
Also it was working fine before the nas OS upgrade...
I understand that, but it is also true that upgrading to Win10 (allowing use of SMB 3) could improve performance.
I wasn't suggesting upgrading everyone, just testing that possibility.
hezner1
Apr 25, 2018Tutor
Unfortunately that is not an option at this point in time.
- hezner1Apr 27, 2018Tutor
So no one else has experienced slow saves in certain applications after the upgrade to a 6.9 OS?
- hezner1May 01, 2018Tutor
- mdgm-ntgrMay 01, 2018NETGEAR Employee Retired
Thanks for sharing the solution.
