hezner1
Apr 24, 2018Tutor
Slow saves for Revit 2018 after OS upgrade from 6.8.1 to 6.9.2
We use the ReadyNAS as a file server for our architectural office. NICs are not teamed. Shadowcopies are not enabled. Everything was working very well until after I upgraded the OS from 6.8.1 to 6....
- May 01, 2018
As a reference to anyone else with this problem, I updated to OS 6.9.3. That version includes the ability to control strict sync on a per share basis. I unchecked strict sync for the affected shares and the save times gone back down to where they were before.
hezner1
Apr 25, 2018Tutor
Unfortunately that is not an option at this point in time.
hezner1
Apr 27, 2018Tutor
So no one else has experienced slow saves in certain applications after the upgrade to a 6.9 OS?
- hezner1May 01, 2018Tutor
- mdgm-ntgrMay 01, 2018NETGEAR Employee Retired
Thanks for sharing the solution.
