DeadByDawn
Feb 12, 2012Aspirant
Slow Speeds DUO RND2000 v1
Hi All, I've got a ReadyNAS Duo (RND2000 v1) and am having major issues with the transfer speed and performance. I have a Neatgear WNDR 4500 which connects my PC and ReadyNas together. I appear to a...
Feb 13, 2012Guru - Experienced User
Yes these numbers are high; it looks like your issue network-related. If you can use different cables (both PC to router/switch and NAS to router/switch) I would try that first. Are you using cat5e or better?
DeadByDawn wrote: Network Errors [Ethernet 1]
Auto-negotiation 1
Bad packets 34
Disconnect 0
False carrier 0
Idle errors 255
Link failures 0
Receive errors 10167
Symbol errors 0
VLAN tags 0
TCP Retransmits 402538
Unrecovered TCP Retransmits 155188
Those numbers look high ? I'll try the direct connect, Give me a few minutes. Thanks for the help btw :)
