DeadByDawn
Feb 12, 2012Aspirant
Slow Speeds DUO RND2000 v1
Hi All, I've got a ReadyNAS Duo (RND2000 v1) and am having major issues with the transfer speed and performance. I have a Neatgear WNDR 4500 which connects my PC and ReadyNas together. I appear to a...
Feb 13, 2012Guru - Experienced User
It could be the NIC, or a setting in the PC or router. Just thinking that checking the cables is an easy thing to try first.
Though if you want to look at settings, make sure flow control is enabled on the PC.
