DeadByDawn
Feb 12, 2012Aspirant
Slow Speeds DUO RND2000 v1
Hi All, I've got a ReadyNAS Duo (RND2000 v1) and am having major issues with the transfer speed and performance. I have a Neatgear WNDR 4500 which connects my PC and ReadyNas together. I appear to a...
Feb 14, 2012Guru - Experienced User
Sounds like the correct next step
DeadByDawn wrote: I've changed the cables with other 5e cables but still no luck with the upload speed. I might connect my laptop up via Ethernet on the same port my desktop uses and see if the issue is still there.
