mike_coreit
Dec 03, 2018Aspirant
Slow to open folders
Hi I have an issue that has started recently after updating the NAS firmware to 6.9.4 and re-inviting the ReadyCLOUD users.
When the users in the office try to open certain shared folders it may ta...
Dec 04, 2018Guru - Experienced User
Are users also using ReadyCloud in the office? If so, try directly accessing the NAS with SMB and see if that helps. It's possible that ReadyCloud is routing the info through the ReadyCloud internet servers (which would certainly degrade performance).
Sandshark wrote:
something more powerful like the 422 (or even a 424 for expansion capability) would be best.
I agree that your NAS is almost certainly underpowered. I suggest considering upgrading it - perhaps using the existing RN102 as a backup. In the meantime, if the Antivirus service is enabled on the NAS, you should turn it off.
Another approach is to deploy a VPN router (or perhaps ZeroTier), and drop ReadyCloud.
mike_coreit
Dec 04, 2018Aspirant
Sandshark The performance of the NAS drive has been fine over the last few years - are you suggesting the firmware update had caused the device to become obsolete?
Retired_MemberI have followed the steps in the performance articles. In an unrelated matter is there any reason why the guide mentions to not encrypt a volume? I don't use encryption at the moment but I may need to the future.
StephenB I have also tried logging out of the ReadyCLOUD app but the issue continues. We do not use the anti-virus on the NAS.
I have checked the resource usage of the NAS and this looks fine only 20% of the CPU and 62% memory.
I may consider replacing ReadyCLOUD with a VPN router but this would be a last resort.
- StephenBDec 04, 2018Guru - Experienced User
I wasn't meaning that. The RN102 was entry level - the slowest processor in the product line, and also the least memory (512 MB). It wasn't recommended for business use by Netgear when it was launched.
It is true that the NAS memory footprint has grown over the years, and the current entry level RN212 has 2 GB of RAM. So memory could be part of the puzzle - though you are seeing only 62% usage, which I think should be ok. Especially since you already have turned off services.
Some other things to look at:
- If "strict sync" is enabled for SMB, then try disabling it. That's on the advanced "Network access" page of the share settings.
- If SMB3 Transport Encryption is enabled, then try disabling it. That might be on the same page, though it might be set globally on system->settings->services->SMB
- If Volume Quota and Checksum are enabled on the system->volume settings wheel, try disabling both.
Also, I suggest looking at the disk health and network stats. You'll find them in the log zip file (disk_info.log and network_settings.log).
If your volume is very old, then you might also do a factory reset, and then rebuild/reconfigure the NAS and restore the data from backup. There have been some improvements/tuning of the btrfs file system along the way, and they can be applied to new volumes.
If you mean Retired_Member's links, those are his suggestions, and they don't come from Netgear. He posted suggestions that he personally found helpful (which is one of the things the community forum is for).
Encryption (both disk encryption and SMB transport encryption) will reduce performance. The RN102 doesn't have AES hardware acceleration. FWIW, the RN422 does have AES acceleration.
- Retired_MemberDec 04, 2018
mike_coreit wrote: "In an unrelated matter is there any reason why the guide mentions to not encrypt a volume?"
It stresses the already weak system resources of an RN10X even more.
That is very easy to understand, if you look at the reading process of a specific file:
unencrypted: access and open the file for reading by the client
encrypted: access the encrypted file for reading, write the unencrypted file into memory (ram or disk) and open the result for reading by the client
Let me leave the difference in writing processes between encrypted and unecrypted files to your imagination.
If you are willing to test you will see significant differences in system performance.
- SandsharkDec 05, 2018Sensei
Did an update make it obsolete? No, it still works, right? But new features can mean heavier use of assets. StephenB mentioned strict sync, and that is something that's a fairly recent addition. Depending on what you updated from, that's certainly a possibility since the default is "on". If you have SSH enabled, go in and use TOP to see if anything is using a high percentage of CPU, with and without somebody currently accessing the volume.
- mike_coreitJan 08, 2019Aspirant
Hi I have tested this over the last few weeks by following the steps. I have disabled strict sync for the share, disabled SMB transport encryption.
There is no quota being used. The disk health looks fine, CPU/memory usage is not high on the NAS.
I have also updated the latest version of SMB Plus 1.0.8, I have set both the minimum and maximum SMB version to 2.0.
It seems the issue continues every 5 days unless the NAS is rebooted. I would much rather not have to rebuild all the data if I can avoid this (though the data is backed up)
I can provide more information - when the issue occurs we can still use command prompt to access the files and directories, they show instantly. Therefore it seems to be an issue with the way Windows Explorer is trying to access the files. Has anyone else come across this issue?
- StephenBJan 08, 2019Guru - Experienced User
I haven't. But I am wondering if rebooting the PC also restores full performance.
