blushark
May 04, 2014Aspirant
Smart TV - lockout my media from ReadyNAS 102
I am missing something here? I am unable to lock out my media files (photos, music, videos) on my ReadyNAS 102 from being viewed on my Samsung smart TV by anyone using the TV. I either want to requi...
May 05, 2014Guru - Experienced User
DLNA is a client/server protocol, so both devices would need to use it. The RN102 has ReadyDLNA and Plex available- you likely set up one when you installed the NAS.
If neither ReadyDLNA nor Plex are active on the NAS, then you must be using a different protocol. Perhaps your SMART TV user manual will tell you what it supports.
But if you are using DLNA, it won't do what you want - the protocol itself doesn't have access controls. Which is a surprising omission.
