Crash_HI
Apr 26, 2025Guide
SMB Stopped working
Hi, I recently rebuilt my ReadyNAS Pro Pioneer RNDP6000 and did a factory reset and installed drives. This unit had been updated to OS 6.10.9. It was working for a few days as I was loading data ...
Apr 27, 2025Guru - Experienced User
Crash_HI wrote:
It seems that the following file
/etc/default/services
contained the line:
USER_HOME_DIRECTORY_SMB_ENCRYPT=(null)
which may have been preventing the SMB service from loading.
Odd, as my own NAS has
and it starts normally.
SMB encryption is configured for each share, and is set to "Enabled" in all my shares.
Crash_HI
Apr 27, 2025Guide
The only think I can think of is that having "(null)" there was causing the problem, since that was a warning in the error log, and I didn't know what else to mess with. I don't know what put that value there, but I posted my finding in case anyone else experiences the same scenario. It seems that removing "(null)" completely would have worked too. I used "default" because that was what I read was one of the valid values for this parameter.
Thanks!
