dschwartzer
Nov 15, 2016Luminary
Snapshot Recovery Mode
I am using a RN526X and have recently enabled Snapsots. In looking at the Netgear video about Snapshots, it makes reference to a Recovery Mode icon that you can click to see the Snapshot files. ...
- Nov 16, 2016
Hello dschwartzer,
I checked again and found that the images do not have option for using thumbnails. However, double-clicking one of the images will open another window that will show all the images of the folder.
dschwartzer
Nov 16, 2016Luminary
JennC:
Thanks for the quick response. I did find the Snapshots button as you suggested and I did restore a file so that is covered.
That said, it seems like you need to know the date or day you want to go back to to find the old file. There doesn't appear to be a way to scroll through multiple Snapshots until you find the file you want. Is that correct?
Finally, when I looked at the online Netgear video which was showing how to restore a deleted photo, the video showed a thumbnail of the photo in the Snapshop folder. My photos just show a generic icon. Since most of my photos have a similar name (img####, etc.) it is near impossible to find the photo you are looking for. Is there something I need to do so I can see a thumbnail of the photo and not just an icon?
David
JennC
Nov 16, 2016NETGEAR Employee Retired
Hello dschwartzer,
Are you using 6.6.0 firmware version?
I will have to take a look again.
