ahellary1
Aug 17, 2017Follower
snapshot volume useage not showing in gui
for some time even before the last 2 os upgrades the volume usage of the snashots is not visable in the gui (ie the yellow usage bar) ready nas 316 im not sure if this will effect the backups as it w...
cs_giuseppe
Aug 17, 2017Apprentice
Hi,
at the volume level Quota is enabled?
if not, then enable and wait .... then see if there is the information
if is enabled then disable quota, reboot the unit, wait a day and re-enable quota.
If possible install fw 6.7.5 if your is older
Giuseppe
