Pawel_W
Oct 07, 2016Aspirant
Snapshots are not visible
Hello! I have a problem after upgrading ReadyNAS OS to version 6.6.0. After upgrading I don't visible snapshots, but space is busy for snapshots. I can't also create manual snapshot (screenshot)...
- Oct 19, 2016
I resolved my problem! I upgraded (dist-upgrade) my NAS and after restart snapshots are visible. :)
JennC
Oct 08, 2016NETGEAR Employee Retired
Hello Pawel_W,
How do you view the Snapshots? Have you tried another web browser?
I tested this on our own unit and it appears to work, I was able to see the existing snapshots and created a new one.
Welcome to the community!
Pawel_W
Oct 09, 2016Aspirant
Hello,
Thanks for answer.
I tested it in another browser and it don't work (I use Chrome, I tested it in Firefox).
At first screenshot is shown that snapshots exist.
But on shares list they aren't visible..
Every of shares has one or more snapshots.
When I set directory for snapshots (in share's settings) this directory is empty. Before software upgrade every of shares had snapshots and they were visible and were avaible.
- mdgm-ntgrOct 09, 2016NETGEAR Employee Retired
Which firmware did you update from? Can you send in your Logs (see the Sending Logs link in my sig)?
