Pawel_W
Oct 07, 2016Aspirant
Snapshots are not visible
Hello! I have a problem after upgrading ReadyNAS OS to version 6.6.0. After upgrading I don't visible snapshots, but space is busy for snapshots. I can't also create manual snapshot (screenshot)...
- Oct 19, 2016
I resolved my problem! I upgraded (dist-upgrade) my NAS and after restart snapshots are visible. :)
Pawel_W
Oct 09, 2016Aspirant
Hello,
Thanks for answer.
I tested it in another browser and it don't work (I use Chrome, I tested it in Firefox).
At first screenshot is shown that snapshots exist.
But on shares list they aren't visible..
Every of shares has one or more snapshots.
When I set directory for snapshots (in share's settings) this directory is empty. Before software upgrade every of shares had snapshots and they were visible and were avaible.
mdgm-ntgr
Oct 09, 2016NETGEAR Employee Retired
Which firmware did you update from? Can you send in your Logs (see the Sending Logs link in my sig)?
- Pawel_WOct 10, 2016Aspirant
Hello,
I upgraded OS from version 6.5.2 to 6.6.0. I sent logs.
Upgrading was done in previous week.
- mdgm-ntgrOct 10, 2016NETGEAR Employee Retired
It looks like this problem is self inflicted. I can see you have installed some stuff on this system using SSH.
Yes, sometimes I updated the system via SSH. I also installed one tool via SSH - rtorrent. I think that I didn't install another programs.
