dschwartzer
Jan 15, 2017Luminary
Snapshots Stopped Working
I had a post on this last week and may have marked it resolved a little too soon. My last post was about not being able to get my Snapsots to back up to my RN314. I did get that working for awhi...
- Jan 15, 2017
Perhaps the snapshots are not being taken due to the disk spin-down?
dschwartzer
Vandermerwe:
Thanks for your response. You are correct that I had Allow Snapshot Access enabled and was looking at the folder contents. I went into Recovery and did see the Delete option.
That said, the recovery folder had the same Snapshot and nothing since Jan. 11. This morning (around 9:00 am I changed the Documents folder Snapshots to hourly and when I just went into it there was still nothing since Jan. 11.
I turned off Snapshots and deleted all of the old Snapshot folders and have re-enabled Hourly Snapshots to see if that works. Any other suggestions?
David
dschwartzer
It has now been almost 7 hours since I cleared out the Snapshots and reset everything to take hourly Snapshots. Not one Snapshot has been created in any of my shares.
Obviously there is something wrong but I have no idea where to look. Any thoughts?
David
