robausirl
Sep 17, 2014Aspirant
SoftEther VPN Issue
Hi, Not sure if this is the right place. However I could not see a section for VPN or Apps. I have setup a ReadyNAS 314 and enabled the SoftEther VPN server. I'm using the config of L2TP and window...
MELDARION
Mar 14, 2015Aspirant
Hi,
have you gotten any replies on this problem I am faxing the same issue. I found this thready http://www.readynas.com/forum/viewtopic.php?f=153&t=74254&p=425694&hilit=softether+vpn#p425694 last reply seems interesting and the solution to our issues however I have not solved them yet. Maybe you could try it out see if it works.
