thc1
Nov 27, 2011Aspirant
[solved] Duo: Frontview[] with ReadyNAS null
Hello together, I set up a ReadyNAS Duo with one WD20EURS. After Installation I tried to configure the NAS, but the only thing I get is an empty screen. I tried with FF 8 and IE 6 to 9. Logfil...
thc1
Nov 28, 2011Aspirant
You can try a direct connection.
Same result.
IE says:
Details zum Fehler auf der Webseite
Benutzer-Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Win64; x64; Trident/4.0; .NET CLR 2.0.50727; SLCC2; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; MDDS; Tablet PC 2.0; .NET4.0C)
Zeitstempel: Mon, 28 Nov 2011 17:34:49 UTC
Meldung: Typen unverträglich
Zeile: 2078
Zeichen: 3
Code: 0
URI: https://192.168.168.168/js/dialog.js
Meldung: 'Dialog.menuArray.length' ist Null oder kein Objekt
Zeile: 2385
Zeichen: 22
Code: 0
Greetings
Claus
