thc1
Nov 27, 2011Aspirant
[solved] Duo: Frontview[] with ReadyNAS null
Hello together, I set up a ReadyNAS Duo with one WD20EURS. After Installation I tried to configure the NAS, but the only thing I get is an empty screen. I tried with FF 8 and IE 6 to 9. Logfil...
mdgm-ntgr
Nov 28, 2011NETGEAR Employee Retired
The WD20EURS is not on the compatibility list (http://www.readynas.com/hcl) so there may be a compatibility issue.
Is your disk a brand new disk? Did you use it at all before putting it in the ReadyNAS?
Seeing that it's a new setup, if you do a factory reset (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu) and clear your web browser cache (i.e. Temporary Internet Files in Internet Explorer) does this make a difference?
