thc1
Nov 27, 2011Aspirant
[solved] Duo: Frontview[] with ReadyNAS null
Hello together, I set up a ReadyNAS Duo with one WD20EURS. After Installation I tried to configure the NAS, but the only thing I get is an empty screen. I tried with FF 8 and IE 6 to 9. Logfil...
mdgm-ntgr
Nov 29, 2011NETGEAR Employee Retired
Yes. If it was the Duo v2 it would say "ReadyNAS Duo v2" not "ReadyNAS Duo" as the model in RAIDar. Also RAIDiator 4.1.7 (Info - far right - column in RAIDar) is firmware for the Duo v1 not the Duo v2.
RAIDiator 5.3.1 is the first firmware for the Duo v2. There is no RAIDiator 5 firmware for the Duo (v1) and there won't be.
That v2 sticker was added to indicate a Duo (v1) with some minor changes to distinguish it from earlier Duo (v1) units.
I am 100% sure you have the v1.
