thc1
Nov 27, 2011Aspirant
[solved] Duo: Frontview[] with ReadyNAS null
Hello together, I set up a ReadyNAS Duo with one WD20EURS. After Installation I tried to configure the NAS, but the only thing I get is an empty screen. I tried with FF 8 and IE 6 to 9. Logfil...
thc1
Nov 29, 2011Aspirant
Okay - but that means a bit of work.
I have access to a compatible disc - a WD10EACS.
Unfortunately it is part of a raid-5.
In this moment the disc is marked as faulty and mdadm is recovering the raid with the WD20EURS.
When this is finished, I make a try with the WD10EACS.
Thanks so far
Claus
Thanks so far
Claus
