shapcah
Feb 09, 2013Aspirant
[SOLVED] Ftp problems after moving, cannot get folder list
hi everyone as the title says im having problems accesing my ftp after i moved house. all the settings are the same exept ofc. having changed masq to the new ip address and doing the port forward in t...
Feb 11, 2013Guru - Experienced User
So the passive port is wrong, and the IP address is wrong. Are you sure you are connecting to the right external IP address?
Also, I am wondering if there is a passive FTP proxy on the path, which is possibly corrupting the messages???
If you are using port 21 for the initial connection (FTP default), try changing it to something else.
