jgrahamiii
Aug 09, 2012Aspirant
Solved: Odd Duo v2 Read Only Access Problem
I have a ReadyNAS Due v2 with the 5.3.5 firmware hooked up to a Windows Network. everyone is using Windows XP to access the drive. There are about 15 users, all of whom need the same access to the ...
jgrahamiii
Aug 11, 2012Aspirant
Found the problem. When I originally created the shares and mapped the drives and copied the files to them, I had the special permissions in Dashboard set to Read Only. This caused the CREATOR GROUP entry in the driver letter to be Read & Execute. I guess this was inherited down the line to the Unix Group/user entry. Fixed that, and it all seems to work fine now. To tell the truth, not sure why, but there are both inherited and non-inherited rights in almost all folders. Very odd. The non-inherited CREATOR GROUP is always READ & EXECUTE, but with the inherited copy of the same group, we get Full Control
