kevinb1
Mar 04, 2015Aspirant
*Solved* OS6 6.2.2 Frontview gone-fixed without SSH
I installed OS6 6.2.2 on a Ultra 6 Plus, been stable for several months now. I ran into a problem with the Monsta FTP app, and tried uninstalling it to reinstall. Oops. Hadn't seen the 6.2.2 bug posts...
mdgm-ntgr
Mar 18, 2015NETGEAR Employee Retired
kevinb wrote:
Unfortunately, word is that the betas do not seem to reliably fix the Apache problem, at least on 6.2.3 Beta 10 and 6.3.3 Beta 10, and I hear rumors of other problems in these Beta releases:
see:
http://www.readynas.com/forum/viewtopic.php?f=154&t=80412&p=455404&hilit=6.2.3+beta#p455404
That problem is already fixed in an internal build so the fix will be in the next public build.
kevinb wrote:
Other issues for the beta seem to be in the categories of network bonding
The network bonding issue relates to 6.3.3 Beta on some ARM systems. It doesn't affect 6.2.3.
kevinb wrote:
system lockups
Users reporting that were already having problems on 6.2.2 on 100 series systems.
kevinb wrote:
backup jobs
That's working a lot better now.
kevinb wrote:
and DVBlink libraries
That's one of the apps that for which waiting for a production firmware update is a good idea, I think.
