kevinb1
Mar 04, 2015Aspirant
*Solved* OS6 6.2.2 Frontview gone-fixed without SSH
I installed OS6 6.2.2 on a Ultra 6 Plus, been stable for several months now. I ran into a problem with the Monsta FTP app, and tried uninstalling it to reinstall. Oops. Hadn't seen the 6.2.2 bug posts...
Nhellie
Mar 20, 2015Virtuoso
Zoocircle,
This is not really recommended if you are not familiar with TelNet, a simple mistake might cause more harm to the unit than good. Best advise would be to contact support and let them access the unit for you,
This issue is caused by Apache not being able to start because of sites-enabled which contained “.conf file” left by the App after its been uninstalled. To solve this, a telnet/SSH access to the NAS is needed and that “.conf file” should be removed then restart Apache and the web-GUI of the NAS will be accessible again.
this is fixed by a beta FW you can find here: viewtopic.php?t=78866
