n0rpan
Dec 13, 2014Aspirant
[Solved] ReadyNAS Ultra 4 (RNDU4000) stuck on booting... #24
Hello! I have traid to find answers on this forum and google, but I could not find anything that work. Hoping for help here :-) My ReadyNAS Ultra 4 was powered off 1 month due to moving to a new...
n0rpan
vandermerwe wrote: Yes, you must verify that the disk you put in is ok.
I have now traid to to a factory reset with only 1 disk at the time with all 4 disks. All fails with "Err could not p" immediately.
I don´t have any way of testing the disks from here, but I would be very suprised if all 4 disks would fail at the same time.
vandermerwe wrote: It's also worth running a memory test using the boot menu, prior to this just check that the memory is seated properly.
I´ve started memory test from the boot menu now after making sure it was properly seated. (I have the original 1024 MB RAM innstalled)
I´ll post back here ones it´s finished.
Thanks for all your help, hoping the someone your talked about could take a look or give som guidance for telnet FW upgrade.
